Problem with Window
14 years 3 months ago #10033 by srshaw3
Replied by srshaw3 on topic Problem with Window
It has been a while, but I recall it was doable, and my hands are not tiny :D
The manuals likely explain the process.
This may work for you as well: nichols.nu/tip029.htm
14 years 3 months ago #10195 by wallyp
Replied by wallyp on topic Problem with Window
Order the roller and the rivet that retains it.
Move the window to the top and securely tape it in place to give you more room. Repeat - "securely tape it in place" - you do not want a guillotine to fall on your hand!
Unbolt the window regulator - the entire lift motor, gearbox and aluminum arm. Wriggle it out of the door. It will come out more easily if you run the arm to a specific configuration - I'm sorry, but it has been so long since I did this that I don't remember whether the arm should be extended or retracted. Be very careful when you move the arm - it is quick and powerful, and could cause severe personal and property damage.
Once you have the unit out, drill the rivet out, put the new rivet and roller in place, and peen the end of the rivet. Wriggle it back in, feed the roller into the track, and reattach the window.
WYAIT (While You Are In There):
- Lubricate the motor bearings, gearbox and arm joints and gears.
- If your window rattles, you can put a few nylon wire ties around the white window guides, or you can replace them.
- Be sure that you properly replace the plastic water protector sheet. If it is damaged, go to the dollar store and buy a cheap ($1) clear shower curtain.
- Lubricate the door lock, hinges, etc.
14 years 3 months ago #10231 by 928mac
Replied by 928mac on topic Problem with Window
wallyp;10508 wrote: Order the roller and the rivet that retains it.
God I like this Wally guy. Great advice man.
Glad you are over here, do you want a job :D
14 years 3 months ago #10233 by Kiln_Red
Replied by Kiln_Red on topic Problem with Window
928mac;10548 wrote: God I like this Wally guy. Great advice man.
Wally has been a highly regarded 928 guru as long as I've been around 928s. He had a more regular presence on the old OC forums. I hope he continues his contributions to this forum here and now. He is of infinite value to anyone who plans on doing any of there own maintenance to their 928 and/or is just getting familiar to them.
14 years 3 months ago #10251 by 928mac
KilnRed;10550 wrote: Wally has been a highly regarded 928 guru as long as I've been around 928s. He had a more regular presence on the old OC forums. I hope he continues his contributions to this forum here and now. He is of infinite value to anyone who plans on doing any of there own maintenance to their 928 and/or is just getting familiar to them.
I am glad of that Austin because I am getting tired of faking it :rolleyes:
14 years 3 months ago #10258 by pcar928fan
Replied by pcar928fan on topic Problem with Window
AMEN TO THIS!!! Wally is a 928 STUD! Few know 928's as well as he does!
