Problem with Window
14 years 2 months ago #10327 by GlennS
Replied by GlennS on topic Problem with Window
Thanks especially to Wally. The window is all the way down (that's the way it was when it failed). The problem was a broken nylon wheel. I am having a replacement wheel made out of aluminum. I removed the window moter and lift assembly to have this done. I did not have to remove the window.
After I get the the new wheel (the shop will do the peening) I will re-install all parts. Hoping I won't have many adjustments and anticipating that re-installing the lift mechanism will be a little tricky.
Thanks for the help all,
Glenn
Glenn Simpson
14 years 2 months ago #10331 by pcar928fan
Replied by pcar928fan on topic Problem with Window
Keep us posted and take very detailed pics and do a Dwayne write up about it for the Tech area!
14 years 2 months ago #10334 by wallyp
Replied by wallyp on topic Problem with Window
I'm glad that you are getting the problem solved - but did want to point out for other folks that the Porsche nylon roller and rivet set costs about $6 plus shipping from your 928 vendors.
You definitely do not have to remove the window, but it is easier if you securely tape it in the closed position.
14 years 2 months ago #10607 by curtisr
Replied by curtisr on topic Problem with Window
I found it really helpful to hold the window in place (closed) by using a couple of spring clamps.
Attached files [img]media/attachments/10939=1282-spring_clamp.jpg[/img]
14 years 1 month ago #11310 by GlennS
I finally finished this job. The problem was the plastic wheel which rides in the window runner broke. I was going to have the replacement wheel made of aluminum when I considered the noise and wear that might result I did not do that. However I did have the replacement wheel made of a much nore durable matrial (nylon), where the replacement wheels are made of plastic.
I posted a couple of pictures to help with some of the references found online. I was able to do this job woth out having to remove the window. I absolute best part of the story it that my car is back on the road again. Thanks for the advice gang.
Glenn
Attached files [img]media/attachments/11649=1334-window job 1.jpg[/img] [img]media/attachments/11649=1335-window job 2.jpg[/img] [img]media/attachments/11649=1336-window job 3.jpg[/img]
Glenn Simpson
14 years 1 month ago #11311 by Kiln_Red
Replied by Kiln_Red on topic Problem with Window
Glenn,
Glad you were able to get it resolved. Now go enjoy! :D
