Problem with Window
14 years 1 month ago #11322
by wallyp
Replied by wallyp on topic Problem with Window
Glad that you got it fixed, and happy to try to help.
While the stock rollers are usually referred to as "plastic", they are also nylon, and typically last twenty to thirty years. At $6, most folks just go with the stock parts.
14 years 1 month ago #11325
Replied by pcar928fan on topic Problem with Window
Isn't it almost always those rollers??? Sometimes the motor, but I think mostly the rollers.
14 years 1 month ago #11327
by wallyp
I would hesitate to guess the relative frequency of failures in the window system. Leaders appear to be:
Switches (can sometimes be repaired)
Motors (can usually be repaired)
Rollers (replace)
Nylon Guides (can be patched w/wire ties, or replaced)
Rubber and Felt Seals (replace)
Most cars need the door internals, including the window system, cleaned, adjusted and lubricated, with worn/aged/failed parts replaced. It is usually worth the effort to go in, clean, lube and inspect to start with.
Rollers (replace)
14 years 1 month ago #11337
Wally,
I was just kind of thinking of the mechanical bits that make it go up and down... True the switches can be iffy, but they usually just get worse over time vs. a catastrophic failure. Also the rubber/felt guides and seals are usually not a deal breaker, but do mess things up.
Speaking of which... How much are those damn felt guides and how easy/hard are they to replace??? My S4's are SHOT! They totally ruined the window tint on those windows too which is VERY frustrating!
BTW, Wally it is SOOOO GOOD having you hanging out with us here! You are one of the most technically skilled and knowledgeable 928 guys I know and your counsel here is priceless! Thanks for hanging with us my friend!
14 years 1 month ago #11339
+928 ^^legend^^
Replied by Kiln_Red on topic Problem with Window
pcar928fan;11676 wrote: BTW, Wally it is SOOOO GOOD having you hanging out with us here! You are one of the most technically skilled and knowledgeable 928 guys I know and your counsel here is priceless! Thanks for hanging with us my friend!
+928 ^^legend^^
14 years 1 month ago #11340
by wallyp
Door Window - Felt Guide '77-'95 (928.537.085.03)
These puppies are $35-40 each, and are a pain to install. While it doesn't make installation easier, you can actually buy good-quality felt at the fabric store and recover the old ones, saving about $150...
