new situation
15 years 3 days ago #6934 by 928mac
Replied by 928mac on topic new situation
whcherman;7091 wrote: mac, that pdf is not willing to open. i will keep trying. but can you explain the relationship between the timming belt and the distributor. most distributors that i have pulled have a gear on the bottom.
No problem but lets get that PDF fixed first.
Stan can you look into Dwaynes timing belt pdf it dose not seem to open.
I thought that it was my work sycurity but it looks like it could be something more.
15 years 3 days ago #6935 by the flying scotsman
Replied by the flying scotsman on topic new situation
The rotor turns as the engine turns but as the belt that drives the cams has perhaps broken the top half of the engine is not moving; camshafts and valves are stationary.
15 years 3 days ago #6936 by whcherman
Replied by whcherman on topic new situation
malcolm;7093 wrote: The rotor turns as the engine turns but as the belt that drives the cams has perhaps broken the top half of the engine is not moving; camshafts and valves are stationary.
thank you, that is what i was trying to understand. so when the belt is stationary or broken the distributor will not rotate. is that correct?
15 years 3 days ago #6937 by srshaw3
Replied by srshaw3 on topic new situation
928mac;7092 wrote: No problem but lets get that PDF fixed first.
There is no issue with the pdf, it is very large, so depending on your bandwidth and computer, etc. it could take a while. I just downloaded and viewed it without issue.
15 years 3 days ago #6938 by 928mac
Stan.Shaw@Excell.Net;7095 wrote: There is no issue with the pdf, it is very large, so depending on your bandwidth and computer, etc. it could take a while. I just downloaded and viewed it without issue.
Stan is it possible due to the size that the browser or network stalls.
I can download others but that one starts but stops around 92k out of the 36meg.
Like I said maybe it is because I am at work.
I am just dubble checking.
Maybe someone else can verify as well, then we will know.
15 years 3 days ago #6939 by srshaw3
928mac;7096 wrote: Stan is it possible due to the size that the browser or network stalls.
I can only tell you that I am downloading it just like you would, I am on a cable connection at home, my servers are on a fiber connection about 25 miles away. I have now downloaded it twice. It is a 36mb pdf, so quite large.
