new situation
15 years 13 hours ago #6927 by whcherman
new situation was created by whcherman
I completed my coolant recovery project and the bad ground, car started. I was bleeding the coolant system while the car was idling. Then a complete shut down. I checked the rotor, not turning, removed cover on serpentine belt not turning. What next.
15 years 13 hours ago #6928 by srshaw3
Replied by srshaw3 on topic new situation
whcherman;7085 wrote: I completed my coolant recovery project and the bad ground, car started. I was bleeding the coolant system while the car was idling. Then a complete shut down. I checked the rotor, not turning, removed cover on serpentine belt not turning. What next.
Are you saying the timing belt is not turning when you attempt to start the car?
If so, do you hear the motor turning over?
If so, then you need to review the timing belt for a break. Fortunately an '84 is US is not interference, so this is just a maintenance project, albeit a time consuming one.
15 years 12 hours ago #6930 by the flying scotsman
Replied by the flying scotsman on topic new situation
Was the water pump replaced when doing the coolant work?
15 years 11 hours ago #6931 by whcherman
Replied by whcherman on topic new situation
Stan.Shaw@Excell.Net;7086 wrote: Are you saying the timing belt is not turning when you attempt to start the car?
yes the motor was turning over. and yes i know it is a time consuming project I have done it before. but since I am a chemical engineer mechanical things i struggle with. just dont understand the relationship between the distributor and the belt. any advice. i would appreciate still learning, after 15 yrs of trouble free porsche.
15 years 9 hours ago #6932 by 928mac
Replied by 928mac on topic new situation
Review this and let us know if you think you can follow it.
928oc.org/Heinsma_Dwayne/pdf/1987_Timing...r_Pump_Procedure.pdf
15 years 8 hours ago #6933 by whcherman
928mac;7090 wrote: Review this and let us know if you think you can follow it.
mac, that pdf is not willing to open. i will keep trying. but can you explain the relationship between the timming belt and the distributor. most distributors that i have pulled have a gear on the bottom.
