Porken Q Ring Install
15 years 20 hours ago #6968
Replied by 928mac on topic Porken Q Ring Install
here is the info Ken sent me on the Q rings
[There isn't a manual or anything. Removal is straightforward, loosen the hose clamps, unbolt the CO sample tubes at the rear. When installing the plenums, loosen both sets of hose clamps, push the plenum toward the intake runners, center the hoses, tighten the clamps while continuing to push.]
Cheers,
Ken
this link is some more info
s300s.com/
I hope this helps
Cheers,
Ken
s300s.com/
I hope this helps
- babromovage
15 years 16 hours ago #6972
by babromovage
Replied by babromovage on topic Porken Q Ring Install
I left it in and removed the negative strap.
- babromovage
15 years 16 hours ago #6973
by babromovage
Thanks Brad. Maybe I will document the process in the spring.
Brian
Brian
14 years 11 months ago #7013
by Glennd
Replied by Glennd on topic Porken Q Ring Install
As Brad stated, removing the air boxes is very simple.
On the passenger side air box (left hand drive), there is a bolt that holds the sample tube. Remove this bolt. Then you can loosen the hose clamps on each of the runners on the air box. You will have 5 - 2 at the back, then the centre T-tube, then two at the front. Once these are loosen, the passenger side will pull out. You may have some small amount of oil in the bottom of the air box.
The driver's side is not as straight forward as there is a vacuum hose at the bottom front. When I remove my air box, I loosen all the hose clamps on this hose arrangement (you have a y adapter here - one hose to the air box, then a venturi within the plastic tube, and then two outlets - one straight and one at approx 30 degree angle). Careful pulling apart this hose collection as to not damage the venturi arrangement.
Once these hoses (at the front of the drivers side air box) are removed, undo the hose clamps on the runners - again, two at the back, the T-tube, and two at the front. A slight effort pulling the air box out sideways and you will be holding the second air box. Again, you may find some oil in the air box. Suggest cleaning out the oil (I just use a rag and let it soak up the oil).
Careful putting the airboxes back in as if you over-tighten the hose clamps on the rubbers, you can damage them (cut into the rubber). You really do not want any leaks on these as it is after the MAF and it will affect your mixture (run lean as more air than measured by the MAF).
Hope this helps.
Storing the car for winter ... what I do:
1) fresh oil and new filter
2) fuel stabilizer
3) run the car to ensure the fuel stabilizer gets into the fuel system throughout the car. Also make sure the engine gets up to temperature to remove any condensation that may appear.
4) park the car and remove the ground strap at the battery.
5) connect a C-Tec 3300 battery maintainer to the battery. According to the literature, you can leave the C-Tec connected all winter - I just power it up for about 48 hours once per month (as there is no load on the battery so it is just internal drain). Given the age/condition of your battery, adjust as required. I have found the C-Tec unit the best of the different brands I have tried.
6) If you can, take the wait off the tires. If not, some folks have parked on small pieces of carpet to help avoid flat spots.
7) leave till the spring ... I know some folks start-up the car during the winter months and let it run for 5 minutes or so. I will not do this as I do not want to create condensation in the engine internals or exhaust.
As spring gets closer, I am sure there will be some great discussions on the best way to bring a car out of hibernation
Cheers
Glenn
Hope this helps.
2) fuel stabilizer
Cheers
Glenn
