Porken Q Ring Install
- babromovage
15 years 6 days ago #6889
by babromovage
Porken Q Ring Install was created by babromovage
Chipped the car with no problem and great improvements. However, I would like to install the Porken TQ Rings but not sure how to remove the plenums. Does anyone have this process documented.
Any insight would be appreciated.
15 years 6 days ago #6890
Replied by 928mac on topic Porken Q Ring Install
Hmm you got me there buddy is there no infor on their web site?
15 years 6 days ago #6891
Replied by srshaw3 on topic Porken Q Ring Install
I see TQ rings listed on the site, but no documentation. I suggest you ask Ken, I have the PK32Vr and it is well documented.
15 years 1 day ago #6962
by Glennd
Replied by Glennd on topic Porken Q Ring Install
Brian,
Drop me a line. One of my 928's is a 86.5 and I have had my airboxes off so many times, I am sure I could help you.
I am also running Ken's chips (version prior to the rings). So if you need help installing the chips, let me know that too.
Cheers
Glenn
Cheers
Glenn
- babromovage
15 years 1 day ago #6966
by babromovage
Replied by babromovage on topic Porken Q Ring Install
Thanks Glenn....Have the chips installed and the car is running great. Trying to maximize the benefit with the Q ring. Where are you located? Also, I out the car in winter storage this past sunday and will pull it out April. Any help or insight into the process would be appreciated.
15 years 1 day ago #6967
Did you remove the battery or leave it in?
I leave mine in because it is in my home garage and easy to start once a month. Not that I need to.
I just like to make sure that the oil gallerys stay full.
which reminds me, I need to order a filter and change the oil.
babromovage;7125 wrote: Thanks Glenn....Have the chips installed and the car is running great. Trying to maximize the benefit with the Q ring. Where are you located? Also, I out the car in winter storage this past sunday and will pull it out April. Any help or insight into the process would be appreciated.
