Vibrating shake when you hit a bump
15 years 1 month ago #6266
by cmgilbe
Replied by cmgilbe on topic Vibrating shake when you hit a bump
Malcolm,
THanks, the rack was leaking as well and I decided to get a rebuild from 928intl. I did see Roger's bushings and considered them.
The tires are relatively new, no real issues noticed outside of inner wear. I anticipate replacing them after the winter.
The shock is an interesting question, not since I have had the car, and I did hit a giant pot hole. But the problems started several months after hitting the hole.
cmg
cmg
15 years 1 month ago #6269
by the flying scotsman
Replied by the flying scotsman on topic Vibrating shake when you hit a bump
shocks are a wear item....how old are they?
15 years 1 month ago #6273
by SeanR
Replied by SeanR on topic Vibrating shake when you hit a bump
My thought is wheel bearing or shocks.
15 years 1 month ago #6321
by cmgilbe
Will install shocks tomorrow. Think this may be the issue. Feels more and more suspension related. Thanks for the advise.
15 years 1 month ago #6350
by cmgilbe
So... I inspected the items suggested. All still look and feel in good shape.
While removing the entire assembly, I had a great view of the tie rods, ball joints upper and lower.
They are shot!
I am ordering the tie rods and lower ball joints. Question at this point is do I need to do the upper control arm as well. This adds about 600 deer to the overall process plus spring/strut removal.
I am inclined to forego the upper and just do the lower and tie rods. Any advise?
They are shot!
15 years 1 month ago #6421
by cmgilbe
Today I removed the tie rods and the steering rack. Photos attached. I ordered replacements for both. Photos will help to illustrate a bad set of bushings and leaking rack for future issues.
Removal took me about 2 hours. The 17mm bolts were the worst due to the nut on the lower half and the bolt in a tight spot above the rack.
Will let you know when I get it put together again.
Thanks to everyone for your help.
Cmg
Attached files [img]media/attachments/6573=760-bad bushings.JPG[/img] [img]media/attachments/6573=761-Rack Leak.JPG[/img]
Cmg
