1990 928 GT with chronic 4 cylinder mode issue
15 years 3 months ago #5802 by the flying scotsman
where did you buy them Brad?
15 years 3 months ago #5804 by srshaw3
SeanR;5947 wrote: Here's another thing to consider, and would not have given it a 2nd thought if it had not happened to my car yesterday.
The ignition modules. My car just started to do what you you are experiencing. Now I know everything on my car is new and these are not, so I swapped a new set in and the car ran great. For $40.00 each, cheap insurance.
I haven't got to any of these tests yet, trying to prepare the M3 for a Lime Rock track day tomorrow.
Just a quick note, that I had previously swapped ignition modules with varied results, as well as the coils. I ended up replacing all of them for both sides (20+ year old car why not). The varied results might be indicative of one of the wiring issues previously suggested. I am particularly interested in checking the O2 sensor, as I replaced it, but haven't looked at it in some time, and did at one time install an RMB, so perhaps tweaked some wiring then.
I am hoping the grounds were previously checked, as it is one of those items I paid to have done, and the intake has been off 3 times since. Nonetheless, I am taking *nothing* for granted, and will check everything one item at a time.
Thanks so much for the suggestions so far!
15 years 3 months ago #5806 by srshaw3
I had a few minutes, so I:
1. Cleaned the ground by the ignition modules, the one that has 4 brown wires coming to it.
2. Swapped the cable connectors from ignition module 1 to ignition module 2 and ignition module 2 to ignition module 1.
I started the car and nearly immediately the green light lit on the IMS relay (as it has been). This indicates the problem is in ignition circuit 2 (cylinder 2,3,5,8. I would conclude the ignition module is not the problem.
As a side note the dash voltage gauge started working again, this has been an intermittent problem.
15 years 3 months ago #5807 by 928mac
Good news, that will be $928.43 split 3 ways please. :D
15 years 3 months ago #5812 by srshaw3
I think you misunderstand Brad, since both ignition modules are new, I didn't expect they would be bad anyways. Finding the cause is what will make me happy, not eliminating as suspect known good parts.
15 years 3 months ago #5814 by 928mac
It was a joke Stan.
That you owe us all some money for helpng you fine your 4 year gremlin :D
I thought $928 was a nice number ;)
