Hood stuck
13 years 4 months ago #15357 by wallyp
Replied by wallyp on topic Hood stuck
Try laying down and looking up to see if you can't see the bottom of the hood latch. If you can, try moving the latch with a long bar or screwdriver.
13 years 4 months ago #15362 by rluvsporsche
Replied by rluvsporsche on topic Hood stuck
I have good news I finally got the hood open using a chanellock. Is there any adjustment that I can make to prevent this from happening?
13 years 4 months ago #15363 by rluvsporsche
Would mind posting a picture of your metal bracket?
emmanuelli;15725 wrote: The plastic frame of my hood release was the first thing that broke after i bought it. Since then i bolted a metal bracket to the side with a screw to hold the casing in place and thankfully my handle is working. However the trick is to make sure the casing doesnt move so the wire can do its job, even if you pull it with pliers as i used to do, it was really hard. Unless your wire is stuck somewhere in between this should work.
13 years 4 months ago #15364 by emmanuelli
Replied by emmanuelli on topic Hood stuck
Not at all. i'll take a snap tonight. i kinda fabricated it.
13 years 4 months ago #15365 by emmanuelli
When it broke i had asked a mechanic i took to the car to, to please put something to hold the wire casing in place. they added just regular wire holders along the wire with rubber dampers on them. It didnt do much cause the casing was sliding freely whenever i pulled on the wire. So i took a piece of metal i had at home, i think it was a bracket to put two wood planks together. I folded it by one of the screw holes and cut it there. Then i screwed it tightly to the side. i passed the wire through where the screw hole "was" and bent the ends tight so it would prevent the casing from moving with the wire when pulled. My lever didnt break, thankfully.
13 years 3 months ago #15370 by 928mac
Replied by 928mac on topic Hood stuck
Good diagram but it gives a whole new meaning to "pulling your wire"
