Hood stuck
13 years 2 months ago #15346 by rluvsporsche
Hood stuck was created by rluvsporsche
Hi All,
I'm having some trouble lately and can't get a break. During the weekend I going to have my AC recharge. While opening the hood the plastic latch broke. Now I'm unable to open the hood. I've pretty much tried everything to pull the cable but it won't release. Can someone direct how to open my hood? I'm afraid I'll have to remove the front bumper just to release the hood latch.
Any help welcome.
Thanks in advance.
Ariel
13 years 2 months ago #15348 by dlbass93
Replied by dlbass93 on topic Hood stuck
I went out and looked at my car, and at the front of the car, the release cable is on the top side of the bumper, and under the hood, so you won't be able to do anything up there. That leaves you having to take the remote release apart inside the cabin, and see if you can pull the cable from there.
I found this: www.nichols.nu/tip282.htm
2015 Red/Black Honda NC700X
2006 Black BMW F650gs
13 years 2 months ago #15350 by rluvsporsche
Replied by rluvsporsche on topic Hood stuck
I tried most of the tips in Greg's site but no luck. I agree there is nothing I can do from up the hood.
13 years 2 months ago #15354 by 928mac
Replied by 928mac on topic Hood stuck
Did the inside part of the cable break off inside the casing?
Can you take a picture of the broken cable that you can see?
13 years 2 months ago #15355 by rluvsporsche
I did not break off inside the casing. I've tried holding it with vice and pliers while pulling the hood handle but it still won't open. I don't think the cable has broken because when I pull on the cable it has tension.
Ariel
13 years 2 months ago #15356 by emmanuelli
Replied by emmanuelli on topic Hood stuck
The plastic frame of my hood release was the first thing that broke after i bought it. Since then i bolted a metal bracket to the side with a screw to hold the casing in place and thankfully my handle is working. However the trick is to make sure the casing doesnt move so the wire can do its job, even if you pull it with pliers as i used to do, it was really hard. Unless your wire is stuck somewhere in between this should work.
