Tires and Cold Weather
13 years 11 months ago #12705 by 928mac
Replied by 928mac on topic Tires and Cold Weather
-21 deg C today or -6 F
I just mark where people freeze to death with head stones and ILL bury them come spring thaw
13 years 10 months ago #13016 by hinchcliffe
Replied by hinchcliffe on topic Tires and Cold Weather
Yeah, but think about how much more sideways driving and drifting you can practice....
I have a '97 BMW 528 that is RWD, throw on the snow tires and turn off the stability control and learn to feel the stick and move. I have so much fun driving in this weather. And you can learn a lot about handling that would be useful when you guys start coming to my DE's........
13 years 10 months ago #13020 by emmanuelli
Replied by emmanuelli on topic Tires and Cold Weather
guess i need to check mine!
13 years 10 months ago #13050 by linderpat
Replied by linderpat on topic Tires and Cold Weather
and for those of us who put them away, be sure to overfill your tires by a few psi, unless you lift the car for the winter.
13 years 10 months ago #13053 by pcar928fan
Replied by pcar928fan on topic Tires and Cold Weather
I usually overfill by quite a lot if a car is going to sit. On the early cars that run 36 I usually go 45-50 and on the rear S4 tires that normally run at 44 I'd overfill to 55. On the GTS's (36 f/r) I'd go 45-50... That is just me, but if the car is only going to sit a couple of months you probably don't need to go as high as I tend to run the pressures.
13 years 10 months ago #13142 by emmanuelli
pcar928fan;13409 wrote: I usually overfill by quite a lot if a car is going to sit. On the early cars that run 36 I usually go 45-50 and on the rear S4 tires that normally run at 44 I'd overfill to 55. On the GTS's (36 f/r) I'd go 45-50... That is just me, but if the car is only going to sit a couple of months you probably don't need to go as high as I tend to run the pressures.
Pardon my ignorance, why do you OVERFILL the tires if the car is going to sit for an extended period?
