Correct part number.
- kennetheryan
I need to know what valve head number goes with camshaft valve head 928 105 251 00.
I am buying a used set and can get either a 346 1R or 356 1R for the valve heads.
Just change the model from 356 to 928, put in the correct year model, and hit "display".
You should find everything you need in the main engine group area 1.
Good Luck
- kennetheryan
The camshaft numbers are actually 928 105 251 1R on my engine. I am buying two valve heads from a US 83-84 engine with camshaft number 928 105 251 00. The person I am buying the valve heads from doesn't know if 346 1R or 356 1R goes with the 928 105 251 00 camshaft head. He has two sets of complete valve heads from two different cars.
I am going to use an 83-84 US engine set of valves that are smaller but will work. (I will have a loss of some performance but I am told this should work.)
kennetheryan;12613 wrote: I believe it has a Euro 83-84 engine. I understand that to be an interferance engine that would bend the valves.
Seeing as your car is a Euro, it is very likely that bent valves is the correct diagnosis.
I think you would absolutely regret swapping to US heads. The drop off in performance would be very noticeable. Not only that, but it just isn't very practical. You could get a complete US engine with the L jet brain, correct intake & injectors, and wiring harness for cheap. Much cheaper than I bet it would cost to convert your engine to US spec. I would call 928 International and get a quote for the correct heads.
