Starting Issue: Need Help
14 years 4 months ago #9610
by denhamfly
Replied by denhamfly on topic Starting Issue: Need Help
If you do get it started again, check the timing again. If is different than last time the pressed ring on your fly wheel is slipping so your timing will keep changing. I chased the same problem for a year and the list of parts that I bought before finding this was as long as my arm.
You might have to play with your timing just to get it started again.
14 years 4 months ago #9615
by Johnny V
Replied by Johnny V on topic Starting Issue: Need Help
Adjusting timing is done via the bolt on the distributor, yes?
14 years 4 months ago #9616
That was the case on my '80 Euro/ROW S. I suspect if you have a distributor with a shaft in your '84 then it is the same. Is yours a US or ROW?
Replied by srshaw3 on topic Starting Issue: Need Help
Johnny V;9883 wrote: Adjusting timing is done via the bolt on the distributor, yes?
14 years 4 months ago #9617
by Johnny V
I have a US 84S. Shouldn't the fact that the car idles smooth for the minute it does stay on mean the timing is ok?
14 years 4 months ago #9619
I am only guessing, but if it is smooth, then perhaps the timing is correct at that time, but as the car warms up or connections get vibrated, etc. the timing could be affected.
I haven't been following the thread, there are better mechanics usually watching this forum, than I will ever be. I am just a very experienced hack
Johnny V;9885 wrote: I have a US 84S. Shouldn't the fact that the car idles smooth for the minute it does stay on mean the timing is ok?
14 years 4 months ago #9620
by Johnny V
I will check it regardless, and I do very much appreciate ANY help or suggestions I receive!
