89 928S4 gauge failure
- whale driver
6 years 2 months ago - 6 years 2 months ago #21363
by whale driver
89 928S4 gauge failure was created by whale driver
Looking for guidance in resolving my loss of gauge info after running out of gas. My working gas gauge falsely indicated 1/4 at the time my engine quit in the middle of traffic. I fortunately was able to drift to the side of the road and made several attempts to start it to no avail.
After Roadside Service came to the rescue with a gallon of gas, I was able to immediately start the car and drive home. After starting the car, I notice all of my digital info and analog tachometer and speedometer were inoperative. The only gauge working was the voltmeter! What's the source of power to the aforementioned gauges? What does the instrument panel function have to do with running out of gas? I have checked the #10 & #44 fuses (they are good) and as a suggestion to reboot, disconnected the battery for 10 minutes. I also, with the key "on", jumped the two wires to the float sensor to see if the gas gauge would move and it didn't. I am still without any gauge indications.
Last edit: 6 years 2 months ago by whale driver. Reason: added info
6 years 2 months ago #21366
Replied by Rich928 on topic 89 928S4 gauge failure
Does the odometer still function? Any function from the trip computer or outside temperature indication?
I would confirm that the instrument pod connectors are firmly connected. if the connector slipped off there would be no display.
- whale driver
6 years 2 months ago #21367
by whale driver
Replied by whale driver on topic 89 928S4 gauge failure
Rich, No, the digital odometer does not display nor do any of the digital windows (trip, temp) display info. The analog speedometer, tach, temp & fuel level are also inop but the voltmeter gauge works as do all of the lights. If the pod connector slipped off, what would allow the anti-skid warninng and volt meter and lighting to continue functioning when the key is turned on?
- whale driver
6 years 2 months ago - 6 years 1 month ago #21369
by whale driver
Problem solved. I had already checked fuses 10 & 44 as advised by others. Another later advised checking # 24 and it was blown. Everything works now. I'm a happy camper.
P.S. Just to explain the reason for the loss of gauges; it was a glove compartment light module that had fallen out of its cubby and shorted out causing the #24 fuse to blow. It wasn't the hard to relate running out of gas! My wife had opened the glove compartment while we were waiting the the rescue service and knocked against the fixture. it was just a coincidence. I confirmed the cause today, when I attempted to reinstall the fixture and caused it to short out with the now known loss of gauges associated with #24 fuse.
Last edit: 6 years 1 month ago by whale driver. Reason: cause of short
6 years 2 months ago #21370
Good news, thanks for sharing the fix.
FYI FUSE 24 is listed as Inside light and diagnostics connection.
The following user(s) said Thank You: just_drive
