warm up regulator fittings
10 years 1 month ago #19301
by nel262c
warm up regulator fittings was created by nel262c
Hi, I'm trying to help a friend with a 79 928. I want to make a control pressure test tool but the WUR/control pressure regulator has a "compression" style fitting on it. Does anyone know what the size is and maybe where I can find a similar fitting? I believe Belmetric.com may have the fitting but don't know what size I need. Thanks
- he_mech_usmc
10 years 1 month ago #19321
by he_mech_usmc
Replied by he_mech_usmc on topic warm up regulator fittings
Rather than "making" a kit, I would highly suggest buying the CIS fuel injection test kit. It will have all of the fittings that you need and the gauge set it set up to appropriately test everything. I was able to source the kit and then added some of my own test parts to it when I was trying to do the testing myself without help. I can get the kit out and take some measurements of the parts needed if you still need them. By buying a kit, it will help with future issues. Common issues on the 77-79 cars are found more in the filter screens in the fuel distributor intake and in the ports to the individual injector lines at the fuel distributor. The screens will get plugged and cause all sorts of chaos with the system.
