New owner
12 years 1 month ago #17651
by pauliesg
I have a 1985 928 S which I purchased this summer from my daughter who moved up to a 911. I do not know of anyone in my area who might be a member of this group nor anyone to contact should/when I need repairs or maintenance. Locally I have someone who can only do an oil change, tire change. No other work on 928's. Anyone in the northern Ohio area? I live in Sandusky, midway between Cleveland & Toledo.
Paulette Grimsbo
Paulette Grimsbo
12 years 1 month ago #17652
by billvvOC
Hi Paulette,
Welcome to the OC!
You can go to the 'OC Info' menu in the header, then select 'Member Contact Map', and then click the two icons on the right (Member and Regional Rep) It will give you a map and if you zoom in and click on an icon you will see the person's name and email address. Try the Regional Rep first or whoever's closest to you. Or both!
And post some photos!
Cheers,
Bill Van Vlack
Welcome to the OC!
Cheers,
Bill Van Vlack
The following user(s) said Thank You: pauliesg
- smtcapecod
- Senior Member
12 years 1 month ago #17655
by smtcapecod
I'm sure you meant to say "moved to a newer 911".... "up to" may not be apropos..
But welcome!
Replied by smtcapecod on topic New owner
pauliesg wrote: I have a 1985 928 S which I purchased this summer from my daughter who moved up to a 911.
But welcome!
- dangibbons
11 years 8 months ago #18070
by dangibbons
1985 928S Moss Green Metallic
Replied by dangibbons on topic New owner
Iannelli's or Galati's in North Olmsted would be able to do any work on your 928.
11 years 8 months ago #18072
I second that comment!
Welcome as well
The following user(s) said Thank You: dangibbons
11 years 7 months ago #18148
HA...surely you jest! In every model year that a 928 was built a 911 was a step DOWN! Now, if newer 911...like say a 996TT or a 997.2 (even n/a version) ok, then a 911 might be a step up...but compared to a GTS those are still just lateral moves!!!
Replied by pcar928fan on topic New owner
