- Thank you received: 13
This is the optional category header for the Suggestion Box
Bug Tracking
12 years 2 months ago #17594
by billvvSU
Replied by billvvSU on topic Bug Tracking
I tried a few as well. Some of the links are legitimately broken. Others will need to be reconstituted on the new site from the old site's database. We'll put that on the list.
Also, we'll have to contact the authors of the posts where there are legitimately broken (offsite) links and ask them to update them or better yet send us the content and we'll host it. They would have been broken before the forum migration, but to maintain the integrity of the OC info we need to do this.
12 years 2 months ago #17604
by billvvSU
I think we fixed 'My Topics', but since I changed my username I can't tell. If someone could check and let us know, that would be great. Thanks.
12 years 2 months ago #17606
by martinss
Replied by martinss on topic Bug Tracking
Yes - it seems to have been fixed. I can see a full range of topics
12 years 2 months ago #17607
by martinss
Registry issue
I attempted to register a car. After filling in the first form and submitting, I was not able to amend the entry by adding additional information about the car as I received an error that an item with that name already exists. I assume that the initial submission was pending approval, and only when approved, would there be an option to edit it. However, the UI is confusing as following the first submission, the same page with additional tabs fro more information is shown, suggesting additions can be made. I assume that a submission should only be made after all desired data has been entered on all of the tabs.
12 years 2 months ago #17608
by billvvSU
martinss.....
You should be able to go back and edit your Registry entry anytime and change everything but the title. The edit feature is a little obscure, but when you find your entry (browse, search) and hover over it you'll notice that unlike the entry above it, there's an additional little - kind of star - on the right side of the popup array of buttons.. Click that and there's a dropdown menu that opens up and gives you the option to edit your entry. The required fields are identified with a menu and with a star next to the fields. The rest are optional.
Try that, and if you have add'l problems let us know.
Since the Registry module is built from a canned Component, we probably can't change the way the edit feature displays, but we will ask the developer of the component if it is possible. And we can work on providing more info about how to access it. I'll add that to the bug list above.
12 years 2 months ago #17611
by martinss
Ah, I see the issue. I had registered my car during the transition period, but never saw it live, so I tried to re-enter, hence the error message. I do not have edit rights but have sent you a request. Thank you..
