24lb injectors in a S4?
15 years 2 weeks ago #6822
Ahhhhh now I understand, I didn't know that the stock injectors were hard to find
Replied by 928mac on topic 24lb injectors in a S4?
malcolm;6976 wrote: this is the car you saw at my place that the owner bought redond Ford 19lbs for and it now runs with a very bad vibe. the decisoin made was to inspect the injectors and one fell apart when bing removed and the pintle dropped down the intake.
Now the thought is to remove the intake, remove the fallen pintle, inspect all for any issues and rebuild with new injectors but the issue now is finding new 19lb units.
15 years 1 week ago #6842
by the flying scotsman
Replied by the flying scotsman on topic 24lb injectors in a S4?
this is a parallel thread as to what I had running on Rlist with the following conclusion:
installing 24LB fuel injectors in a unmolested 87 S4 without specific sharktuning would cause issues and the stock 19LB FIs should be used with the 4 hole Ford units giving better spray and added horse power.
hope this helps others pondering same
15 years 1 week ago #6861
So dose this mean that we should not install #24 injectors on our cars?
15 years 1 week ago #6864
Unless you have the ability to sharktune AND and other power related items (exhaust, cams, etc.) then YES, DO NOT INSTALL 24lb injectors
15 years 1 week ago #6877
Im also going to add that if your attempting to any fuel related work on your 928 or any car for that matter you should have a great amount of mechanical experience.
As noted in another thread there can be very severe consequences for fuel related issues.
