Fuel Stabilizer
15 years 1 week ago #6774 by srshaw3
Replied by srshaw3 on topic Fuel Stabilizer
KilnRed;6913 wrote: That's all that is necessary for a "winter storage." Fuel doesn't go bad over the course of a season change. I don't use any fuel additives in any of my cars. Not that I'm against them. I just don't see the point of the expense. If storing for a long time or if I'm unsure when I will run a car again as I am getting into an extensive project on one, I will cut off power to the fuel pump, run the car until the rails and injectors are dry. Then I will replace the fuse/relay for the pump and drain the tank. And there aren't many tanks out there as easy to drain as the 928 thanks to its in-line fuel pump. :D
Data point, with government mandated ethanol U.S. gas does go bad, and starts to be obvious as soon as 3 weeks. I had a generator go bad a few months ago, and the "fuel" didn't even smell like gas anymore....
15 years 1 week ago #6780 by the flying scotsman
Replied by the flying scotsman on topic Fuel Stabilizer
stan.....are there other countries that have same ethanol petrol conditions?
Was in Scotland this summer.....no ethanol but $$$$$ We dont have much in Canada.....probably would freeze :D
15 years 1 week ago #6782 by srshaw3
malcolm;6935 wrote: stan.....are there other countries that have same ethanol petrol conditions?
I don't know, but it is quite the farce. Raises the cost of gas, lowers octane, decreases shelf life of gas (not sure there was a shelf life before this) and of course also raises the price of food, since they used a crop that could feed people.
I haven't seen any proof that it helps with its intended cause in any way. Of course Iowa is an early presidential primary state.... Am I cynical?
15 years 1 week ago #6787 by martinss
Replied by martinss on topic Fuel Stabilizer
Most gasoline in Canada is 10% ethanol. The mandated minimum is 5%. E-85 is generally not available. Here's info from one of our largest gas vendors = Petro-Canada: retail.petro-canada.ca/en/fuelsavings/143.aspx
Personally I fill the tank before storage - decreasing the volume of reactive air to gasoline. I also use the highest octane I can get since it already has more additives. If I can I wait until near winter since the additive package in winter gasoline is different in my locale to reduce the chance of freezing.
15 years 1 week ago #6794 by denhamfly
Replied by denhamfly on topic Fuel Stabilizer
Sometimes it gets in the 30’s here, I have had my beer freeze at that tempture, but never my gas. Gas will go bad season to season. That keeps my son in business he works on small engines, but that is only if you let it evaporate and you let the light hydrocarbons out, so keep you gas cap on and your tank full.
15 years 1 week ago #6795 by babromovage
Replied by babromovage on topic Fuel Stabilizer
Wow. Varying opinions. Not sure what I should do. I would like to add a few points that may offer recommendation. The car will be stored in a temperature controlled car storage facility.
Brian
