Heads
15 years 2 weeks ago #6650 by denhamfly
Heads was created by denhamfly
Bent valves, is there a procedure to remove the heads?
15 years 2 weeks ago #6657 by 928mac
Replied by 928mac on topic Heads
Oscar, do you have the engine out?
And yes we have this link found in our technical library under Engine Cylinder head removal
forums.928oc.org/vbulletin/showthread.php?t=540
15 years 2 weeks ago #6663 by Kiln_Red
Replied by Kiln_Red on topic Heads
Oscar, round up the tools and follow the WSM's procedure for removing & installing the engine. Mount it to an H-type stand and then disassemble the top end. You can do most, if not all, of this work yourself with the right tools and the WSM. With a little patience, you can easily handle the job. It's the magnitude of the project that makes it easy for folks to feel defeated and give up.
