no voltage
15 years 2 months ago #5960 by monte928
no voltage was created by monte928
I was starting her up and it started to crank but didn't run the first time but thats normal and when I let go fo the key I lost all my power. I've been troubleshotting but haven't found anything yet. any body have any ideas I can try.
15 years 2 months ago #5961 by srshaw3
Replied by srshaw3 on topic no voltage
monte928;6106 wrote: I was starting her up and it started to crank but didn't run the first time but thats normal and when I let go fo the key I lost all my power. I've been troubleshotting but haven't found anything yet. any body have any ideas I can try.
I don't see any details, so please provide more, what year and model, auto or manual, etc. What do you mean by no power? Have you checked the battery to see whether it is charged and the connections are good?
15 years 2 months ago #5962 by monte928
Replied by monte928 on topic no voltage
Sorry, Its a 1978 euro manual yes I have checked the battery and it has a full charge and the connections are good, I have voltage out to the stud on the left fender
15 years 2 months ago #5963 by srshaw3
How about voltage to the starter from the battery? There is a direct cable from the rear for that.
You said "no power" but haven't said what that means. Do your lights work? Radio? Does your ignition key allow accessories to be turned on?
15 years 2 months ago #5964 by monte928
sorry again, no when I turn on the key nothing works
15 years 2 months ago #5965 by srshaw3
Could be your ignition switch or perhaps a relay. There are many tips at nichols.nu/cat02.htm
