central warning system
- john a. volak
15 years 4 months ago #5237
by john a. volak
central warning system was created by john a. volak
1998 s4, when hitting a small bump, central warning light comes on, also brake pad light in dash comes on. when hitting warning light switch on dash it goes off. all brake sensors are gone how do i fix problem? i check brakes every year and they are great. i read somewhere how to disconnect sensors if this is the problem anybody know how to accomplish this? i like to do things right so would it be better to replace sensors? i have had so much accitance with this web site that makes things work. thanks so much for your help, john
15 years 4 months ago #5238
by N2O-928
Replied by N2O-928 on topic central warning system
Hi John, to disable the sensors at each wheel all you need to do is to tie the two sensor wires together. I have seen this done on an '80.
The sensors are not very expensive, I would just replace them with new and check all the connections for good contact, WD-40 is your friend when it come to electrical connections.
Good luck,
Dave
Good luck,
Dave
- john a. volak
15 years 4 months ago #5389
by john a. volak
Replied by john a. volak on topic central warning system
thanks dave, i.ll try this and see what happens, john
- WyattsRide
15 years 4 months ago #5391
by WyattsRide
Huh? :confused:
Replied by WyattsRide on topic central warning system
john a. volak;5377 wrote: 1998 s4,.........
Huh? :confused:
15 years 4 months ago #5395
Replied by 928mac on topic central warning system
John must mean an 89 not a 98.
Thats why its always good to have your car in your sig
- john a. volak
15 years 4 months ago #5409
by john a. volak
sorry guys, it is a 1988 not 98. thanks john
