have you done mains with engine in car
16 years 3 months ago #302 by srshaw3
B.W.Haugen;323 wrote: one thing that caught me off guard was the pin/dowel to the front bearing
Time for a break... BTW the last time I saw an engine with this design and quality was on a top fuel drag car. :-)
I do recall the front bearing having a pin in it, presumably to keep it from spinning. Definitely ensures it will be put in only one way.
Yes, the engineering of the whole car is really far above most other cars. I always enjoy the fact that parts come off as they went on, even 20+ years later. Not like the mass produced, short term life expectancy parts found in so many other cars.
16 years 2 months ago #334 by 928mac
Quick question;
In the manual for torquing the mains the last step is 55 lb/ft + 4
is the +4 deg, ft/lbs or flats. I hope its lbs.
Waiting for an answer as I am torquing it now
Thanks
16 years 2 months ago #340 by 928mac
well the bottom end is all back together. The 10m studs final torque is 55 the 8m is 37 and the 6m bolts are 15 (hope the 6m stay)
took me from 9 this morning till 2, done for the day.
Engine comes out in the fall so I will recheck everything then.
16 years 2 months ago #341 by srshaw3
B.W.Haugen;358 wrote: Quick question;
Thanks
What was the answer :) ?
16 years 2 months ago #342 by 928mac
928racer;365 wrote: What was the answer :) ?
I don't know, I hope it is just the tolerance.
16 years 2 months ago #343 by srshaw3
B.W.Haugen;366 wrote: I don't know, I hope it is just the tolerance.
The "4" sounds more like pounds than degrees, from the few times I have seen degrees listed, it usually 90', 45', etc. "4" would seem to be an unusually exact number of degrees.
