Front control arms
16 years 2 months ago #679 by rluvsporsche
Replied by rluvsporsche on topic Front control arms
928mac;711 wrote: 928 MS have a ball joint rebuild kit for the upper A-arm
Application for 78-86 only. I do appreciate the help but end up buying a rebuilt unit.
16 years 2 months ago #1005 by 87 Shark
Replied by 87 Shark on topic Front control arms
A arms have been on for 3months now and am very pleased with the handling and ride. I did have an issue with a creak comming from the left front that was not present with the old control arms. I allowed the car to settle in but the creak would not go away. After talking to many different sources I was told repeatedly that it sounds like a bushing problem. The new control arms eliminate the upper bushings. The car was to tight after the install. A can of wd40 and sprayed all remaining bushings and all is as it should be.I would recommend the steel arms as a cost effective alternative to the original control arms.
16 years 2 months ago #1008 by srshaw3
Replied by srshaw3 on topic Front control arms
87 Shark;1040 wrote: A arms have been on for 3months now and am very pleased with the handling and ride. I did have an issue with a creak comming from the left front that was not present with the old control arms. I allowed the car to settle in but the creak would not go away. After talking to many different sources I was told repeatedly that it sounds like a bushing problem. The new control arms eliminate the upper bushings. The car was to tight after the install. A can of wd40 and sprayed all remaining bushings and all is as it should be.I would recommend the steel arms as a cost effective alternative to the original control arms.
Great, thanks for the feedback :D
16 years 2 months ago #1027 by 928mac
Replied by 928mac on topic Front control arms
rluvsporsche;504 wrote: sorry I meant 5/8 shorter than OEM from center on ball joint to the mount towards inside of the car. The are not reversed, the can only mount one direction.
I wonder if there is a diff in years and they sent you the wrong ones
16 years 2 months ago #1039 by rluvsporsche
928mac;1062 wrote: I wonder if there is a diff in years and they sent you the wrong ones
You’re probably right. The vendor finally agreed to send me OEM rebuilt. I've installed the OEM back. I'm waiting for the suspension to settle before getting it aligned. I also drop the car to my liking. It's approximately 1.5-2 inches top of the tire to fender lip.
