- Thank you received: 9
Oils and ZDDP
13 years 10 months ago #13126
Replied by mm928 on topic Oils and ZDDP
Good to know Normy....if you think Michigan is hot, try 100% humidity in VA....sheessshh.
Enjoy FLA...
Enjoy FLA...
13 years 9 months ago #13301
by Normy1
Hah hah! I know what you are talking about. I just got done watching the national news and the pictures of buildings covered with ice! It was 76F/24C here today. I spent the afternoon in a pair of shorts and no shirt scraping the barnacles off the bottom of my boat in the front yard.
N
Replied by Normy1 on topic Oils and ZDDP
Strat_928;13483 wrote: Good to know Normy....if you think Michigan is hot, try 100% humidity in VA....sheessshh.
Enjoy FLA...
N
13 years 9 months ago #13310
You ol sea dog!
13 years 9 months ago #13343
by Normy1
Every dog in the neighborhood has sniffed my swale the past few days....
N
Strat_928;13668 wrote: You ol sea dog!
N
13 years 9 months ago #13377
by ROG100
Replied by ROG100 on topic Oils and ZDDP
Lots and lots of interesting information out there about oils.
I moved away from Mobil 1 15W 50 because of issues with availability. I also take a lot of notice of the really experianced mechanics (work on Porsche cars for a living). Bruce Buchanan in Australia is once such guru and has about 25 years experiance with oils and Porsche cars.
They use 15W 50 or 20W 50 oils with over 1200 levels of ZZDP and have never seen lifter wear, cam wear or thrust bearing wear (auto and manual) EVER. The only cars they see wear on are cars that use lower viscosity oils or oils without the correct level of ZZDP period.
I personnaly use Royal Purple 20W 50 on all my cars and also customer cars. I think the actual oil supplier is mute as long as the viscosity and ZZDP levels are correct.
If you check your owners manual Porsche only recomends 15W 40, 20W 40 & 20W 50 for our cars that operate 5F to 100F. That must cover a large proportion of 928 owners.
13 years 9 months ago #13397
Replied by Kiln_Red on topic Oils and ZDDP
I would hesitate at recommending 15w-40 as an acceptable viscosity for our engines. I am not aware of any formulation of that viscosity that has greater than 800ppm zddp. That is not to say it doesn't exist, but I believe it may be very hard to find. 15w-50 is would I would suggest. Perhaps it was just a typo.
