Euro S Heads
16 years 7 months ago #208
Ya 928racer i was looking at the X pipes but i decided that the cost was a bit more then I could handle. with the canadian shipping and exchange and duty i only spent 1/2 of what they would have cost me.
BTW as to keep with the thread post I was looking through those pdf manuals that i downloaded (not sure which forum) and there were lots of specs for most of the years and euro engines Rich. maybe they would be a help. If I find the thread again ILL come back and post a link.
found it
www.cannell.co.uk/928_Workshop_Manuals/1...20Wire%20Diagram.pdf
Replied by 928mac on topic Euro S Heads
928racer;227 wrote: You know there are X pipes out there that would be an improvement over the straight cross pipe, right?
The filter assembly looks nice, I think it is often used when motors have forced induction.
found it
16 years 7 months ago #220
There are several performance benefits to this setup
a) 5 liter vs. 4.5 or 4.7 liter = more displacement = more power
b) Euro top end, as said by others larger valves, larger throttle body, larger intake runners support better airflow = more power
c) Euro cams = better profile for higher RPM power, less low end torque. I really need 3,000 RPM to get power (vs. better low-end on 32 valve motors)
d) Headers/custom exhaust = more power
The car weighs around 2700 lbs, so it is a good bit lighter. All the better for the track, helps the 4 piston Brembos slow down well.
My Euro engine with the improved exhaust puts out similar HP to my GTS, but lacks the low end torque.
Replied by Rich928 on topic Euro S Heads
Richter12x2;217 wrote: Is there a performance benefit to using the Euro heads on the 5.0L block? Or is there another reason?
