rear hatch wiring
- john a. volak
15 years 10 months ago #2829
by john a. volak
rear hatch wiring was created by john a. volak
you guys are too good, thanks for your help. now my next question. the hatch wires are red, brown , and yellow. what feed the yellow wire? i checked red and yellow wires at pull up knobs at front seats and they had voltage,now only the red has voltage which sounds correct to me. what does the yellow wire do? maybe part of turning off motor for hatch? i replaced relay but it made no difference. any help would truly be appreciated. thanks, john
15 years 10 months ago #2832
Replied by Kiln_Red on topic rear hatch wiring
The red should always show power with the ignition in the run position. The yellow wire should only show power when the switch is closed. Then, in a perfect world, the power is distributed via the yellow wire to the motor and the hatch is released.
- john a. volak
15 years 10 months ago #2844
by john a. volak
Replied by john a. volak on topic rear hatch wiring
thank you for comment, now i will try again to get this straightn,t out.
