Brake Pressure Warning - Flashing
1 year 8 months ago #22850 by Gatornapper
Today I rebuilt my LR brake caliper and fully bled the line to the caliper.
Initally all was well.
But quickly the "!" warning lights and "Brake Press" warning began flashing.
The brakes work fine with no softness, and the fluid reservoir is full.
Can anyone tell me why this is happening and how I can get the warning flashing to stop?  I drove car about 10 miles, testing brakes, turning engine off and on and warning light continue to flash.
Is there a way to reset the brake system?
TIA,
GN
1 year 8 months ago #22851 by NickTucker42
One thing that comes to mind is perhaps the float switch was disturbed while you were performing the bleeding.  Make sure it is seated and the connector is tight.  If it continues use a multi meter to check the operation of the float and verify the switch is functional.
I would start there.
There is no reset for this but as a very last resort you can always try disconnecting the battery for 10 minutes.  This of course will "reset" everything.
1 year 8 months ago #22857 by Gatornapper
Thank you = will try battery disconnect soon.
GN
1 year 8 months ago #22860 by Gatornapper
Battery disconnect fixed everything!
All is well!
Thanks!
GN
1 year 7 months ago #22862 by NickTucker42
Excellent!!
Glad to hear it all worked out!
