what tools are a must have ?
16 years 3 weeks ago #1789
by 87 Shark
what tools are a must have ? was created by 87 Shark
I defer to the experienced here. Beyond ratchets, wrenches and screw drivers, what tools are a must have to work on the 928. I would like to start a list for us newbie mechanics. What do we need , what is it for and were do I get one. I'm interested in guauges, scanners, gear pullers, what works and what does'nt. Should I rent or buy and if you can what jobs can I do with them. I'm hoping this can helpus direct our dollars to where it will do the most good(and create a great christmass wish list)
16 years 3 weeks ago #1795
Replied by pcar928fan on topic what tools are a must have ?
87 Shark is SERIOUS about his 928 work! NICE! I tell you the tool panel in the back of the car is pretty good for most things you would need to do, but obviously isn't going to take care of the big stuff like you want to do!
My hat is off to you! While these cars are pretty complex there really isn't anything that is over the head of even a modestly competent wrench turner! You can save a lot of money turning them yourself too!
I think the problem has always been how crappy the Work Shop Manuals (WSM's) are for the novice. They assume a HUGE amount of knowledge about not just working on cars but working 928's before you even start...so most of us look at a WSM write up and then go back inside and just have another beer. To get to the vacuum stuff behind the dash step one would be: REMOVE DASH! OMG...REALLY! How many of us could look at that step one and just go, "ok, lets do it." Not many. Thankfully there have been many REALLY GOOD write ups on stuff like that here in the 928 community!
16 years 2 weeks ago #1862
Replied by 928mac on topic what tools are a must have ?
Opps Sorry, I was going to make a list.
OK this will be quick and anything I miss, you guys just add it in.
I will try to stay away from the professional grade of tool for you and we will see what Craftsman has to offer.
Craftsman 16 in. Pliers, Arc Joint
item #00945384000
Craftsman 10 in. Pliers, Slip Joint
item #00945380000
Craftsman 6 in. Pliers, Diagonal
item #00945075000
Craftsman 8 in. Pliers, Needle Nose
item #00945085000
or get sets its cheaper
Craftsman 5 pc. Pliers Set
item #00945419000
Mfr. model #45419
http://s.shld.net/is/image/Sears/00945419000-1?wid=400&hei=400&op_sharpen=1&qlt=75
Craftsman 75-piece Combination Tap & Die Carbon Steel Set
item #00952377000
Mfr. model #52377
NaN 2 ratings
http://s.shld.net/is/image/Sears/00952377000?hei=400&wid=400&op_sharpen=1&qlt=90,0&resMode=sharp&op_usm=0.9,0.5,0,0
Craftsman 7 pc. Standard Flex Socket Set, 6 pt., 3/8 in. Drive
item #00934445000
Mfr. model #34445
NaN 2 ratings
....................and
Craftsman 7 pc. Metric Flex Socket Set, 6 pt., 3/8 in. Drive
item #00934446000
Mfr. model #34446
NaN 5 ratings
These will make your life very easy
http://s.shld.net/is/image/Sears/00934445000-1?wid=400&hei=400&op_sharpen=1&qlt=75
Craftsman 6 pc. Metric 3/8 in. dr. Hex Bit Socket Set
item #00934448000
Mfr. model #34448
NaN 8 ratings
Craftsman 7 pc. Torx Bit Socket Set, 1/4 and 3/8 in. Drive
item #00934449000
Mfr. model #34449
NaN 2 ratings
http://s.shld.net/is/image/Sears/00934449000-1?wid=400&hei=400&op_sharpen=1&qlt=75
item #00945384000
item #00945380000
item #00945075000
item #00945085000
item #00945419000
Mfr. model #45419
item #00952377000
Mfr. model #52377
NaN 2 ratings
item #00934445000
Mfr. model #34445
NaN 2 ratings
item #00934446000
Mfr. model #34446
NaN 5 ratings
item #00934448000
Mfr. model #34448
NaN 8 ratings
item #00934449000
Mfr. model #34449
NaN 2 ratings
16 years 2 weeks ago #1863
Craftsman 26-3/4 in. Pick Up Tool (magnet)
item #00904132000
Mfr. model #4132
NaN 1 ratings
Craftsman 2-1/4 in. Telescoping Mirror
item #00941603000
Mfr. model #41603
NaN 2 ratings
Craftsman 1/2 to 3/8 in. Socket Adapter
item #00904259000
Mfr. model #04259
NaN 4 ratings
Craftsman Professional 5 pc. Metric Full Polish 12 pt. Deep Offset Box End Wrench Set
item #00944350000
Mfr. model #44350
NaN 4 rating
http://s.shld.net/is/image/Sears/00944350000-1?wid=400&hei=400&op_sharpen=1&qlt=75
Craftsman 2 pc. Qtr-Turn® Convertible Retaining Ring Pliers Set
item #00947385000
Mfr. model #47385
OK OK this is getting old fast, if you get that there is a lot to list, so lets just say go buy this
Craftsman 432 pc. Professional Mechanics Tool Set $719.99
item #00936432000
Mfr. model #36432
NaN 4 ratings
http://s.shld.net/is/image/Sears/00936432000-1?wid=400&hei=400&op_sharpen=1&qlt=75
OH you will need a box to put all that in
www.craftsman.com/shc/s/p_10155_12602_00...binet+Combos&prdNo=5
https://s.shld.net/is/image/Sears/009H0019000-1?hei=400&wid=400&op_sharpen=1&qlt=90,0&resMode=sharp&op_usm=0.9,0.5,0,0
You will still need a nice meter and also a good 12 volt test light
Craftsman Digital Multimeter with Auto Ranging, 11-Function
item #03482334000
Mfr. model #82334
User Rating: 5 ratings
This would be a good start for anyone wanting to maintain there car
Torque wrenches and other stuff as you need it
I am on my 4th box due to growing out of them.
This one is a $4500 Mac Tech 1000 tool box and somewhere around $30,000 of hand tools (mostly Snap-on and Mac)
item #00904132000
Mfr. model #4132
NaN 1 ratings
item #00941603000
Mfr. model #41603
NaN 2 ratings
item #00904259000
Mfr. model #04259
NaN 4 ratings
item #00944350000
Mfr. model #44350
NaN 4 rating
item #00947385000
Mfr. model #47385
item #00936432000
Mfr. model #36432
NaN 4 ratings
item #03482334000
Mfr. model #82334
16 years 2 weeks ago #1875
by Mike Frye
Replied by Mike Frye on topic what tools are a must have ?
OK, that's a pretty general but comprehensive list.
I'm going to go with some more specific stuff.
Gotta have a flywheel lock tool and Kempf tensioner tool.
You've got a multi-meter on there, I prefer a FLUKE meter. Your preference, needs autoranging voltage and resistance (ohms), nice to have is a top of the line unit that can be used as a tach.
Liftbars from Ken are an absolute must-have.
While you're there, I'd order a 'blink'r' and a 32v'r cam timing tool.
I'd also go with some service covers, low range jack (for use with your liftbars) and good jackstands with a round top that lines up under the lifbars.
If you don't have a full mechanics set of tools, you need to have 1/2 inch drive 27mm deep well socket (for steering wheel nut and also crankshaft turning). 17mm allen socket for draining the trans (some are 10mm), better make it a full set of allen sockets.
