Oil Change
3 years 1 month ago #22498 by reichspeed
Oil Change was created by reichspeed
I have a 1978 928 and haven't changed oil for a while so when doing so the oil will not drain down from the fill canister to the motor. Seems as though something is blocked. Any suggestions?
3 years 1 month ago - 3 years 1 month ago #22504 by Rich928
Replied by Rich928 on topic Oil Change
As the diagram illustrates, there is a screen (#30a) that may be clogged and is in need of cleaning.  If you remove that the oil should flow into the engine.  If it doesn't there may be a block in the line down to the oil pan.
Last edit: 3 years 1 month ago by Rich928.
