10 Speaker System in my 95 GTS, WWYD?
3 years 6 months ago #22411
by 3KCapital
10 Speaker System in my 95 GTS, WWYD? was created by 3KCapital
So I am looking to add all OEM 10 speakers that came with the 95 GTS. What would be the best way to hunt these down? Any recommendations as to what you would do?
3 years 6 months ago #22412
Replied by Rich928 on topic 10 Speaker System in my 95 GTS, WWYD?
These are the speakers and part numbers. They are likely no longer available from Porsche. You may be able to locate used speakers from a dismantler or similar sized speakers from an audio specialist.
3 years 6 months ago #22413
by 3KCapital
Replied by 3KCapital on topic 10 Speaker System in my 95 GTS, WWYD?
Thank you.
3 years 6 months ago #22414
Did your 928 GTS not have speakers or are they damaged? If they are damaged, there are many shops that can re-cone or re-foam them. This would be the best solution if possible.
I had the rear woofers in my 1993 GTS rebuilt.
There have been many people who had stereo shops change to different speakers. The main problem is there isn't much space available behind the speakers for large magnets and the stock Porsche system has low resistance speakers that are different from most aftermarket speakers so the amplifier is also replaced. If the stock amplifier is replaced a lot of wiring modification is required.
On a separate note, I replaced my 1993 GTS original radio replaced with the Porsche Classic radio. I had a custom plug fashioned so the original amplifier was retained. It is a nice addition and adds blue-tooth, hands free telephone and GPS navigation.
