Skittish about Body Work – Glass Breakage
16 years 1 month ago #1683 by GlennS
I have rust at the bottom of the rear hatch glass and the bottom of the driver’s side rear quarter panel. I took the car to the shop I normally use for body work to get an estimate for the repair. The owner of the shop told me he was really hesitant to do the job. He is concerned about either the hatch or quarter panel glass breaking during removal. He said to repair the car properly would require removing the glass. I located a glass outfit that will go to the body shop and do the glass removal and installation. However, considering the concern of the body shop guy I want to be prepared for the worst.
I understand rusting at the bottom of the hatch glass area is common because water naturally collects there so I’m hoping someone has some experience getting this job done. If so please tell me what you’ve learned from your experience. Also does anyone know the cost to replace the rear hatch glass or any other glass? Do you have a recommendation for a source to get replacement glass?
Thanks,
Glenn
Glenn Simpson
16 years 1 month ago #1691 by SeanR
Removing the hatch or quarter glass is, by far, the most simple glass removal on the car.
Replacements are all over the place and that will not be a problem, so don't sweat a break. If they break it, they shouldn't have your car to begin with.
For removal of the hatch glass, pull the inside trim including the rear sun visors and the above roof liner (hatch only). Under there, you will find a million screws, take those out (hold downs for the hatch window). Then all they need to do is slowly move it off the hatch. It does have sealant, but it is not that strong, and running a wedge in there will seperate the glass from the hatch. Resealing has to be done properly, but shouldn't be an issue with anyone who has done glass before.
The Quarters are bit harder, but easily done. Start from the inside, by pushing the seal outward at any point, the seal contains the window, and by folding the inner seal over the body edge. Once you have a section going, following the contour of the window, pushing the seal out, you will be fine.
Installation is the reverse and I use weed wacker line to do both the window seal and the window trim. Using a spray bottle with soapy water helps with both.
16 years 1 week ago #1940 by rluvsporsche
SeanR;1742 wrote: Removing the hatch or quarter glass is, by far, the most simple glass removal on the car.
QUOTE]
SeanR
Your absolutely right they shouldn't have the car to begin but it’s difficult to find a place that really knows 928’s since there rare and few around. If you ever do this again do you mind doing a DYI in video or other on this procedure?
I've never found a body shop around here that could say they can remove these glasses without breakage. Everyone tells me the same even the body shops that work on Porsche.
Thanks
Ariel
16 years 1 week ago #1941 by pcar928fan
Any ham fisted body shop moron should be able to get the qtr glass out w/o breaking it... Trust me I have seen some of these guys. They can't find their butt with both hands, but they can get that quarter glass out w/o breaking it. The hatch would be more of a concern just because it is such a HUGE heavy piece of glass.
Sean is correct, you can find this glass just about anywhere... You will likely need new seals around the QTR glass though so budget for that. I think passenger side is a bit over $100 but drivers side is more like $200 for some reason...
16 years 1 week ago #1944 by 928mac
pcar928fan;1995 wrote: Any ham fisted body shop moron should be able to get the qtr glass out w/o breaking it... Trust me I have seen some of these guys. They can't find their butt with both hands, but they can get that quarter glass out w/o breaking it. The hatch would be more of a concern just because it is such a HUGE heavy piece of glass.
Thats because one is a lefty and one is a righty he he he
16 years 1 week ago #1945 by srshaw3
I may resemble that remark.... but I have removed both rear quarter glass and hatch glass without assistance and without damaging them :D
I have heard the same can be done with the windshield glass, but not yet by me :eek:
