- Thank you received: 9
Early CIS O-Ring Issues
5 years 9 months ago #21765
by joejabq
Early CIS O-Ring Issues was created by joejabq
Now that I have gone through my '79's CIS system and that it seems to be running fairly well, I wanted to ask if others have reoccurring issues with the fuel distributor O-rings, particularly the two with the pressure regulator. Those two O-Rings appear to really take a beating.
CISFlowTech point to ethanol in the fuel.
I'm sure that's right and also lack of use that allows them to dry out.
I'm just wondering if people have any magic bullets, like a Viton O-Ring supplier!
5 years 8 months ago #21784
by joejabq
After consulting with Rich and others with early model year cars, I’m now thinking that 10% ethanol is not an issue. I’m starting to think that letting the o-rings dry out, either from lack of use or having a system that doesn’t retain residual fuel pressure (I had both of these) is the more important factor.
Replied by joejabq on topic Early CIS O-Ring Issues
joejabq wrote: Now that I have gone through my '79's CIS system and that it seems to be running fairly well, I wanted to ask if others have reoccurring issues with the fuel distributor O-rings, particularly the two with the pressure regulator. Those two O-Rings appear to really take a beating.
