1991 928 engine overheat
6 years 2 months ago #21444
by jackson63
1991 928 engine overheat was created by jackson63
What happens when you overheat a 928? Car ran well until it was overheated now it will not start.
6 years 2 months ago #21445
by Trainer
Replied by Trainer on topic 1991 928 engine overheat
The same thing happens when any engine overheats. All hell breaks loose. You have ruined it my friend .If it is not totally locked up you are lucky
6 years 2 months ago #21446
Replied by Rich928 on topic 1991 928 engine overheat
I suggest changing the oil & oil filter first thing as the oil may be burned and no longer lubricate well. If coolant was lost it should be replaced.
Next, determine the cause of the no-start, like any other no-start. Is it no spark, no fuel, no/low compression etc.
Lastly, determine why there was an overheat condition. Were the cooling fans not operating (one fan in-op)? Was the coolant level low/a coolant hose leaking or broken?
