Fuel supply 1982
6 years 2 months ago #21436 by jan
Replied by jan on topic Fuel supply 1982
HI again
Again thanks for explanation of the power supply.
I hope to see the pump soon and will give it some external 12 volt. I have rigged up so i can see voltage when cranking and will monitor that. jumping the relay is a good option as well. This one needs a lot of love, but getting it running so not too much is stuck and corroded is first step.
6 years 2 months ago #21437 by joejabq
Replied by joejabq on topic Fuel supply 1982
Good Luck! Please let us know how it turns out!
6 years 2 months ago #21438 by jan
Yes I will follow up with progress and pictures for the next guy
6 years 2 months ago - 6 years 2 months ago #21439 by jan
Hi again
will try to see if i can get a picture attached from the fuel pump, filter, hose thing.
I am not able to upload pictures here. PLease let me know what i am doing wrong.
I chose a picture under Add File and insert, but nothing comes up.
Last edit: 6 years 2 months ago by jan.
6 years 2 months ago #21440 by joejabq
I found that I had to either decrease the resolution of the pictures or make them smaller to post
6 years 2 months ago #21447 by jan
HI again
Now i received the aftermarked fuel pump that is a bit smaller that the original Bosch that was in there.
New check valve, copper rings, filter and gas. Car starts but dies right after it has started. I can start it a few times and then it does not start. If i then wait some minutes it will start again, but it will not continue to run.
So is it the fuel pump that is not giving sufficient pressure to run, or is it feed back from engine ??
I can hear the pump run after the car stalles until i turn the key off.
Any advice ??
