More problems
16 years 5 days ago #1978 by Kiln_Red
There isn't anything more challenging in doing an intake refresh than there is doing a timing belt job. If you've done the timing belt then you're more than qualified to do tackle this one yourself as well.
16 years 5 days ago #1980 by 928mac
The ring gear teeth are not the same as the reluctor teeth unless your standard is different then my auto 89.
In the picteure below of my ring gear and reluctor gear, you can see the heavyer teeth at the bottom left in behind the ring gear
16 years 5 days ago #1983 by Kiln_Red
928mac;2034 wrote: The ring gear teeth are not the same as the reluctor teeth unless your standard is different then my auto 89.
Yes, it's the same for standard 928s. The Hall sensor would be unaffected by a worn starter ring. You are correct.
16 years 5 days ago #1984 by 928mac
You know, I was just thinking how much fun it would be to right something on that plate for the next guy to see. Then I was thinking that only I work on my car BUT! anyone that takes there car in sure could have fun. Like a small bag of flour tucked up under the dash, he he he
16 years 5 days ago #1986 by Kiln_Red
Never even considered it but that is genius! Actually, now that I think about it... When I bought a used car once, the PO left his old license plate on it. Probably not too smart. Anyway, when I got mine in and decided to swap them out, a sheet of notebook paper fell to the ground when I removed the old plate. I picked it up and read what was inside. It was an amateur poem or song of some sort about sexual violence. Seemed like the author found it euphoric. Very creepy.
The vehicle was a Mustang GT BTW. :p
16 years 5 days ago #1993 by 928mac
KilnRed;2040 wrote: Never even considered it but that is genius! Actually, now that I think about it... When I bought a used car once, the PO left his old license plate on it. Probably not too smart. Anyway, when I got mine in and decided to swap them out, a sheet of notebook paper fell to the ground when I removed the old plate. I picked it up and read what was inside. It was an amateur poem or song of some sort about sexual violence. Seemed like the author found it euphoric. Very creepy.
Oh great, now ILL be known as the underneath guy.
