Formuling France hub for 928??
16 years 1 month ago #1494 by Pcplod
Anyone know where I can get a hub to fit a Formuling France steering wheel to my 86.5 928?? I have looked around but nothing is available for these wheels anymore. I assume they went under or something, but I love the wheel and would like to put it in my car....
Thanks for the input!
Paul
16 years 1 month ago #1495 by srshaw3
Is that the brand and actual model of the steering wheel?
If not, do you know what they are?
If you can provide dimensions of what is needed, someone might be able to compare those to adapters to see if one could be used, or modified to be used. I think I have a momo somewhere to compare to.
16 years 1 month ago #1496 by Pcplod
Stan.Shaw@Excell.Net;1540 wrote: Is that the brand and actual model of the steering wheel?
Stan,
The Formuling is weird because it has 9 screws attaching the wheel to the hub. Here is a picture of a wheel so you can see the arrangement. I will go out to the garage and measure it to see what the hub measurements are. This has always been my favorite wheel, although it does not look as cool as some today, and I would love to be able to use it again.
Attached files [img]media/attachments/1541=136-Formuling.jpg[/img]
16 years 1 month ago #1497 by Pcplod
Okay, measured the wheel. From #1 to #4 (1/3rd of the way around) is 3 5/16", the hub is about 4 1/4" across, and just going from #1 to #2 is about 1 5/16".
I guess I could just get a new wheel, but this one has some sentimental value, so if anyone knows a way that I could use it, I would be a happy camper. :D Otherwise, I guess I will put it on the wall and go buy a Momo. :cool:
Attached files [img]media/attachments/1542=137-PA030025.jpg[/img]
16 years 1 month ago #1498 by srshaw3
Pcplod;1542 wrote: Okay, measured the wheel. From #1 to #4 (1/3rd of the way around) is 3 5/16", the hub is about 4 1/4" across, and just going from #1 to #2 is about 1 5/16".
Do you have the adapter that it came with? I would expect you could have some weld the top half of that adapter to the bottom half of a Momo adapter. You would need to get a Momo adapter for a 928 and then cut it apart.
Keep in mind that there is a reasonable chance that an adapter for your wheel to the 928 never existed.
16 years 1 month ago #1511 by OBehave
If you send me the wheel and a Momo adapter for a 928 I'll make it work for you fairly easily. Ed
