1985 - 1986 928 Idle Speed Regulator System
7 years 8 months ago #20760 by Rich928
This attached PDF document outlines the idle speed regulator driver circuit evaluation.
A customer of mine was experiencing a high idle speed condition and requested his LH fuel injection module to be tested. This article outlines the testing.
The high idle speed problem was found to be caused by vacuum leaks and an aftermarket ISR Valve that didn't function properly.
