1988 928S4 Instrument Panel
9 years 10 months ago #19456 by mrgrinch2000
Now that winter is here I am getting ready to dive in.
Wish me luck!
9 years 10 months ago #19469 by Kiln_Red
What are your findings thus far?
9 years 10 months ago #19488 by SeanR
Replied by SeanR on topic 1988 928S4 Instrument Panel
The odometer not working is the typical broken gear. The fuel level reading 3/4 is always misdiagnosed as the sending unit when in reality it is due to a well worn rear backing circuit board on the instrument cluster. Replacing that will eliminate a great many issues with the gauge readings.
9 years 9 months ago #19504 by LummoxPG
Yes, as SeanR has stated the sending unit replacement advice is the usual knee jerk reaction to any fuel gauge issues. My fuel gauge wouldn't read any more than 1/2 full even when it was. This was rectified by pulling the curcuit board and cleaning the connections. Not saying that is the problem but I would say that is where you should start, that said that quote you received seems somewhat high. Pelican Parts can provide you with a new sending unit that will most likely be cheaper than what the dealership quotes and replacing that part is something that you could very well tackle on your own. Should save you a great deal of cash. There are some great write ups on Rennlist and Pelican regarding removal and cleaning of the instrument panel...ok I'll admit that I was a little apprehensive myself with the procedure... all I can say is "if I can do it you can too". Best of luck.
1988 Porsche 928 S4/SE
1993 BMW 535 i
2001 Mercedes CLK 320
9 years 4 months ago #19857 by mrgrinch2000
I got started and chickened out.
Took the car to an expert.
Got the odometer repaired and speedometer recalibrated.
Total cost $800
Had all the burnt out dash bulbs replaced at the same time.
9 years 4 months ago - 9 years 4 months ago #19859 by y33trekker
mrgrinch2000 wrote: I got started and chickened out.
Boooo. Hisssss. J/k. :P
Total cost $800
Had all the burnt out dash bulbs replaced at the same time..
However it happened, it's always nice when an issue has been resolved and the vehicle is drivable again. Good to hear.
Last edit: 9 years 4 months ago by y33trekker.
