Idle issue
- rluvsporsche
16 years 2 months ago #1080
by rluvsporsche
Idle issue was created by rluvsporsche
I found my idle issue after some extensive testing. I have to replace the vacuum line from the fuel tank vent diaphragm to throttle body. Is there a technique to replace this line without removing the intake manifold? Does someone know how flappy vacuum solenoid located on the driver's side front cam cover works?
16 years 1 month ago #1094
Have you seen this? nichols.nu/tip442.htm
Replied by srshaw3 on topic Idle issue
rluvsporsche;1115 wrote: I found my idle issue after some extensive testing. I have to replace the vacuum line from the fuel tank vent diaphragm to throttle body. Is there a technique to replace this line without removing the intake manifold? Does someone know how flappy vacuum solenoid located on the driver's side front cam cover works?
- rluvsporsche
16 years 1 month ago #1342
by rluvsporsche
Now I have. Thanks Shaw.
Replied by rluvsporsche on topic Idle issue
Stan.Shaw@Excell.Net;1129 wrote: Have you seen this? nichols.nu/tip442.htm
