Wheel Question
11 years 2 months ago #18477 by lowpue
Wheel Question was created by lowpue
I want to keep my new 1986 928 as close to stock as possible but I do not like the skinny tires on the back. Want to beef up a bit and was considering getting 1987 flat disc 8" wheel however, it has an offset of 52.3 instead of 65 offset currently on the car with 7" wheels. This means the wheel will stick out 1" more than before. Is there any issues with rubbing.or sticking out too much.
THanks in advance.
2015 Porsche GT3 (4,400 miles) DD Sun
2009 Porsche 911 C4S PDK (22,000 mi) DD Rain
2000 Porsche 911 C2 Aero (52,000 mi) Track Car
1987 Porsche Targa - (90,500) preservation
1986 Porsche 928 - (122,600 mi) preservatio
1967 Porsche 912 - (93,000 mi) project
11 years 2 months ago #18478 by mm928
Replied by mm928 on topic Wheel Question
There can be, some are not too concerned with the lower offsets to get the right look. Others do not like to test the designers decisions...that much :)
Just do a search if you do not get many responses,,, it is indeed well discussed here and elsewhere
If you need 65 offsets, you can get the Manhole covers like I have (16 inch, on my 83) or maybe some are on 84's, or on older model years. You will likely not find any that high again until the GTS model and not many of those are made,,, and they are 17 in, I keep an eye out for those myself
After market? Good luck,,, I not yet found offsets that high, unless you have the wheel built,,,, quite expensive.
