928 Water Pump Timing Belt Time Estimate
11 years 7 months ago #18164 by JohnnyDiesel
I have a 1982 928 and need to do the water pump and timing belt. How much time should i set aside for this job? I have done multiple belts before, but not on a porsche. Do you often have problems such as sheared bolts, or are they fairly straight forward? Thanks for any tips, greatly appreciate it!
11 years 7 months ago #18165 by linderpat
There are lots of gotchas in this job, from sheared water pump bolts to setting the cam sprockets. I strongly encourage you to check out rennlist 928 forum where there is a ton of information on this job, with excellent tutorials. If you are going o replace your water pump, you also must be sure to not buy a rebuilt, and get one only with the plastic impellor. Again, excellent and in depth information on rennlist for this.
