need help with rear hatch
16 years 2 months ago #954 by 928mac
Replied by 928mac on topic need help with rear hatch
The hatch is heavy. I would be turning the key and jerking the hatch up and down lots first.
16 years 2 months ago #956 by rluvsporsche
928mac;989 wrote: The hatch is heavy. I would be turning the key and jerking the hatch up and down lots first.
I'll try that again. Only problem is I have the adjustable wing that keeps poping out. Do you think lubricating key hole help?
16 years 2 months ago #957 by rluvsporsche
Stan.Shaw@Excell.Net;988 wrote: Sorry, I don't.
NP at least I'm getting some info how to deal with this problem. Any suggestion always helps.
16 years 2 months ago #962 by 928mac
rluvsporsche;991 wrote: I'll try that again. Only problem is I have the adjustable wing that keeps poping out. Do you think lubricating key hole help?
It can't hurt.
I would also climb inside, remove the back cover and watch while someone else tries. you might see what is hanging it up. Take a screw driver with you to pry at the release cam.
16 years 2 months ago #965 by Kiln_Red
Replied by Kiln_Red on topic need help with rear hatch
928mac;997 wrote: It can't hurt.
I second that suggestion.
16 years 2 months ago #1019 by rluvsporsche
I finally got the hatch open using a screw driver prying the plastic cam. I found the upper latch has stress marks. Also the plastic cam does not move. My repair manual does not show how to remove the latch from the alarm wiring. Does anyone have suggestion? Is it normal for the aluminum upper latch to crack? Thanks for all the help. Ariel Trajano
Attached files [img]media/attachments/1054=115-P1010966.jpg[/img] [img]media/attachments/1054=116-P1010968.jpg[/img]
