interior lights
16 years 1 month ago #1433 by john a. volak
Replied by john a. volak on topic interior lights
Pcplod;1464 wrote: Not sure what year/transmission setup you have, but when my interior delay relay (XXI) was bad, I did not have any reverse lights and the automatic transmission indicator lights in the gauge pod were so dim that you couldn't see them. Don't know if that is helpful or not, but I thought that I would throw it out there. ;)
my reverse lights work, along with auto trans. light, thanks for commenting.
16 years 1 month ago #1460 by Kiln_Red
Replied by Kiln_Red on topic interior lights
Pcplod;1464 wrote: Not sure what year/transmission setup you have, but when my intreior delay relay (XXI) was bad, I did not have any reverse lights and the automatic transmission indicator lights in the gauge pod were so dim that you couldn't see them. Don't know if that is helpful or not, but I thought that I would throw it out there. ;)
This is why I asked whether the interior lights worked as they should if the hatch was opened. If so, then you can bet on a bad relay.
16 years 1 week ago #1912 by john a. volak
i installed a new relay XX4 and non working lights worked again, came on when door was opened. about 1 hr. later i took car for ride and lights came on and stayed on, wouldn't turm off. my new relay was used from 928 international could it have been bad? what can i do with problem. 1988 S4. thanks, john
16 years 1 week ago #1916 by 928mac
Replied by 928mac on topic interior lights
Take the relay out and tap it on the flood or bench.
Put it back in and see if it works any different. If it does its the relay.
Also you can try one from another spot that looks the same, just to see if it is the relay or a different problem.
