Acceleration not clean
16 years 3 weeks ago #833
by CARLO
Acceleration not clean was created by CARLO
Hi,
One other issue, on accerating I get a pulsing or hesitation throughout the RPM range up to 4000, haven't taken it higher. New fuel pump, fuel filter, coil, K&N air cleaner and dist cap. I used some Techron thru a tank of fuel hoping it might clean the injectors but didn't help. Plugs look nice and light brown. NOTE>>>THIS CAR SAT FOR 4 YEARS when I bought it, did not run. I thought I would:
1. Remove injectors and have them tested and cleaned.
2. Replace new injector seals.
3. New SP Wires.
Any suggestions ?
3. New SP Wires.
Any suggestions ?
16 years 3 weeks ago #836
Replied by srshaw3 on topic Acceleration not clean
I suggest you provide specific car information as it will vary widely, 928, 928S, 928S4, etc. years, US or ROW.
- Brett928S2
16 years 3 weeks ago #837
by Brett928S2
Replied by Brett928S2 on topic Acceleration not clean
Hi
Suggestions....
New rotor arm, new plugs and maybe new leads....
All the best Brett
Suggestions....
All the best Brett
16 years 3 weeks ago #841
Replied by Kiln_Red on topic Acceleration not clean
Definitely check the injectors before you bother doing anything else. Also, check your vacuum with a vacuum gauge. This could also reveal a blocked catalytic converter. Exhaust back pressure can cause hesitation. Might not be a bad idea to go ahead and get a new O2 sensor too.
Can you be a bit more descriptive about the hesitation? Also, do the symptoms change once warm?
16 years 3 weeks ago #848
by CARLO
Replied by CARLO on topic Acceleration not clean
Thanks for the replys.
The car is a US 1983S, I also replaced the rotor. Warm or cold as you give it more gas and the revs go up it's not a clean acceleration, tends to pulse, hard to explain. I will try all your suggestions one at a time to see if I can isolate the problem. Thanks again.
16 years 3 weeks ago #850
Vacuum leaks are a big issue with 928s, as suggested here, a small crack in a intake boot may allow unmetered air to enter the intake, so I would put this near the top of the list, particularly if the car has sat for quite a while.
I had an '82 that would barely run, because the intake had loose clamps on the intake boots to the runners.
