HOT window winder relay
13 years 3 weeks ago #16164
by probinson
HOT window winder relay was created by probinson
Any suggestions, window relay 928.615.126.00 is so hot you can't touch it even with the ignition off. Windows and sunroof work fine. This breaker was draining the battery overnight. Seems like if the breaker is bad nothing would work. Switches and motors seem to work fine.:confused:
13 years 3 weeks ago #16166
by the flying scotsman
Replied by the flying scotsman on topic HOT window winder relay
first, disconnect the battery and avoid a potential fire.
what year and model of car?
13 years 3 weeks ago #16172
by probinson
Replied by probinson on topic HOT window winder relay
1985 928s, I have pulled the relay and battery is not draining
13 years 3 weeks ago #16179
by Normy1
Replied by Normy1 on topic HOT window winder relay
"Any suggestions, window relay 928.615.126.00 is so hot you can't touch it even with the ignition off. Windows and sunroof work fine. This breaker was draining the battery overnight. Seems like if the breaker is bad"
First of all, what year?
Second, what is a "breaker"? A circuit breaker is a device that fries when too much current goes through it. It is a protective device. A RELAY is an "automatic switch". Think of it as a switch that uses power to close itself. The two devices are completely different.
Your post is confusing. I suspect that it is the relay that you are talking about, a black box about 1 inch square that is on the fuse and relay panel under the passenger floor boards. A little heat is normal, but so hot that you cannot touch it isn't. I'd replace this and see if the new relay gets hot.
N
N
13 years 3 weeks ago #16181
by probinson
Correct...it is the relay, used to working with electrical panels.
13 years 3 weeks ago #16182
by probinson
I will replace the relay, the old one was so hot the plastic case was soft. Strange that everything worked...sun roof and windows.
