CO Test Pipe
13 years 2 months ago #15832 by mm928
Replied by mm928 on topic CO Test Pipe
Ditto - there are various ways of plugging pinching, just depends on your situation and accessibility. Did mine while the engine as out.
13 years 1 day ago #16264 by N2O-928
Replied by N2O-928 on topic CO Test Pipe
928mac;16129 wrote: Mine are pinched off
Hi you do know what you pictured is not the "Co Test Pipe", right ?
They run directly into the Exhaust cast iron headers.
That hard metal pipe covered in foil is one of the two "Exhaust Temp Sensors" (one per side) that screw into the Head.
These are for the CAT protection system to detect Cylinder Temp difference, mostly set off by a failed Ignition bank, the system then cuts of the injectors to that bank so it doesn't dump fuel into dead cylinders.
Just don't want to see anyone messing w/ those as they run about 500 bucks EACH! ;)
Dave K
13 years 12 hours ago #16266 by the flying scotsman
Replied by the flying scotsman on topic CO Test Pipe
Brad.........Dave's comments are correct.....your car is just a little different given its ex Japan.
The CO test ports are pipe thread......I installed a couple of short bolts and get rid of the pipes completely :)
12 years 11 months ago #16286 by 928mac
Replied by 928mac on topic CO Test Pipe
Thanks for catching that Dave. I learned something new.
12 years 11 months ago #16288 by gcthree
Replied by gcthree on topic CO Test Pipe
I seem to have seen a photo where someone had put a cap on the manifold fitting, and I was wondering if anyone knew where you could source it? I fit a short bolt into the fitting and then held it in with the ferrule....but a cap would be so much nicer....
Bob
Second Time Around 928 S4
12 years 11 months ago #16296 by 928mac
It may be best to contact 928 international
