Engine does not want to start after rebuild-ideas
13 years 4 months ago #15171
by xstepson
Replied by xstepson on topic Engine does not want to start after rebuild-ideas
JDoran,
The reason I asked about the harness in the first place was to find out whether you are using a CPS or the green wire. I would think you would have to have one or the other to tell the ignition when to fire. Since you posted that don't have a green wire, I am to assume that you are using a CPS. But if that is the case, then how are you using the '80 distributor? I am starting to believe you are having a mix and match issue.
As posted by Wally above, let us know what you find.
13 years 4 months ago #15266
by Jdoran
Replied by Jdoran on topic Engine does not want to start after rebuild-ideas
Gentlemen- the beast is alive. The culprit - stuck plunger in the CIS fuel distrubuter. I found a local mechanic and he found the sticker plunger. A little work, dry the system out and it started right up. Drained/replaced oil and it starts right up, set the timing and it throttles right up. Putting on the road this weekend. If you need a porsche mechanic in the virginia beach, va area I found one. It took him all of 10 minutes to see it.
I want to thank all of you for your help. Thank you!!!!
Final components, 1984 m22 lower, 1980 m11 heads and cam. CIS injection with Mercedes injectors. No air pump, .005 of the heads, we estimate 10.75, compression 155-165 throughout. New arness, 1980 harmonic, 1980 sprockets for timing belt, 200 amp alt. and jut about everything else.
Let everyone know how the road test goes. Again -thanks to all
13 years 4 months ago #15267
by wallyp
Replied by wallyp on topic Engine does not want to start after rebuild-ideas
Congratulations!
I hope that you made certain that all of the timing belt components matched - "round-tooth" vs "square-tooth"...
13 years 4 months ago #15274
Replied by 928mac on topic Engine does not want to start after rebuild-ideas
Cool, thats what I like to see.
Now when you get it running good enough for a video drive by, please post one for us.
I love to see a car pull away from a stop. Hint; bald tires spin easier
13 years 4 months ago #15281
Replied by pcar928fan on topic Engine does not want to start after rebuild-ideas
Keep us posted on how it is running and post some pics!
13 years 4 months ago #15329
by Jdoran
It' all square tooth and will post pics shortly.
It does sound awesome!
