16 years 1 month ago #1481 by Mrmerlin
after rereading this post I would check the the charge rate.
if its below 13.5 then you have a bad diode in the alternator.
If the gauge isnt working then this is another issue that needs to be looked at,
you might have a bad connection at the pod or the connection at the 14 pin connector under the hood. Check the voltage with the car running at the hot post
16 years 1 month ago #1492 by 928mac
Mrmerlin;1526 wrote: after rereading this post I would check the the charge rate.
Hey Guys, do all the main wires run through that 14 pin connector?
If so that is the first place I would check for any other problems.
Low volts (voltage drop) or high resistance in the grounds.
I should check mine. (I'm so dam Lazy) don't forget to use dielectric grease after cleaning, before it goes together
